Router bit set for binding - Which one? http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=5759 |
Author: | Mark Tripp [ Tue Mar 21, 2006 6:52 am ] |
Post subject: | |
Hey Gang: I am going to be receiving my binding jig from Craig Holden in a couple of weeks, and need to get a bit/bearing set. StewMac has one for around $85.00 with eight bearings - LMI has one for $144.00 with ten bearings - and one of our sponsors, Luthier Suppliers, has one for $150.00 with a boatload of bearings, unfortunately, they are backordered until the end of April. ![]() So... What to do? Have two boxes waiting for binding, and will have two more done by the time the jig arrives. Do I wait, or should I just go ahead and get one of the others, and if so, which one? I make Dreads, some with Herringbone purfling, some without, if that makes a difference. -Mark |
Author: | tl507362 [ Tue Mar 21, 2006 7:12 am ] |
Post subject: | |
Mark, I don't think I'll be able to get those bit/bearing sets anymore. ![]() Also, the good thing about the LMI kit is that you can just get the set with the 10 bearings, and if you find that you need another bearing, you can just order that one bearing from LMI. But 10 should be enough to get you started. If I ever start carrying them again, you will be able to mix and match the bearings from LMI with my cutter. Good luck! Tracy |
Author: | Don Williams [ Tue Mar 21, 2006 7:13 am ] |
Post subject: | |
Bummer Tracy! I was hoping to order a set some day from you. Rats. |
Author: | Dave Rector [ Tue Mar 21, 2006 7:35 am ] |
Post subject: | |
Tracy, will the LMI bearings work with the set I bought from you last year? |
Author: | Mark Tripp [ Tue Mar 21, 2006 7:48 am ] |
Post subject: | |
Thanks guys! Knew I could get options AND answers here! Tracy: Sorry you can't get those anymore - looks like a great set! Thanks for the tip Hesh! - I do indeed have that binding tape. I take it the StewMac - LMI bearings are not interchagable? -Mark |
Author: | A Peebels [ Tue Mar 21, 2006 8:02 am ] |
Post subject: | |
I use the stewmac bit and bearings set. It does a good job, now only if someone would do the same thing with a downcut bit they would have the ultimate binding cutter. Al |
Author: | tl507362 [ Tue Mar 21, 2006 9:08 am ] |
Post subject: | |
Dave, Yes, the LMI bearings will work with the cutter you bought from me. Good luck! Tracy |
Author: | Dave Rector [ Tue Mar 21, 2006 10:32 am ] |
Post subject: | |
Tracy, thanks for the info. I certainly don't need any right now, but was thinking about if I ever needed a replacement. |
Author: | Brock Poling [ Tue Mar 21, 2006 12:38 pm ] |
Post subject: | |
I have both sets. I prefer the LMI set, simply because it has more bearing sizes... both are nice though. |
Author: | Mattia Valente [ Tue Mar 21, 2006 7:49 pm ] |
Post subject: | |
So, Tracy, if the time comes that I need a new router bit (not bearings), and you don't have any, I'm safe with LMI's bit? |
Author: | Jimmie D [ Wed Mar 22, 2006 5:21 am ] |
Post subject: | |
What's the ID size of the Stew Mac and LMI bearings? I have several Rabbet bits. All I need is the right size bearings. |
Author: | tl507362 [ Wed Mar 22, 2006 5:31 am ] |
Post subject: | |
Mattia, That is correct, you will be okay using LMI's bit with my bearings. I have both sets, so I know it works. Jimmie, I'll try to measure the ID of the bearing and report back this afternoon. Tracy |
Author: | tl507362 [ Wed Mar 22, 2006 2:43 pm ] |
Post subject: | |
Jimmie, Looks like the ID of the bearing is .290". If I really press tight with my caliper around the post that the bearing rests on, I can get it down to .285". But I think .290 is more accurate. Also, make sure you are using a 1" diameter rabbet bit, or these bearings will not work so good. Good luck! Tracy |
Author: | Jim Watts [ Wed Mar 22, 2006 3:31 pm ] |
Post subject: | |
Hesh, I used to use that trick with tape with a cmt rabbit bit but once had the tape come off, so double check everything really well and clean the surface of the bearing with a wipe or alcohol/acetone before putting the tape on. It's a very good trick just double check to make sure everything was clean befor routing. I now use LMI's bit and like it very much. |
Author: | Jimmie D [ Thu Mar 23, 2006 11:09 am ] |
Post subject: | |
Tracy, Thanks for the info. I have a couple of 1" rabbeting bits. I'll go measure them and see what I come up with. Thanks Again |
